hey guys! Im wondering if 69 and 70 brake pedal supports are the same? Will a 70 pedal and support work in a 69? If I use a 70 brake booster? Thanks!!
They are different. I think WCCC has pics/info. Not exactly sure the would swap. Booster mounting is same. The way it is at the connection to lower dash is where they differ IIRC…
They changed them due to the steering column change which also changed the design of the lower dash.
A 70 booster will not work with a 69 pedal with a 69 support. It puts the pedal right at the lower edge of the dash.
Thanks for the info!
