I figure I`ll put this out in case a needle in a haystack is found.
ISO a pass side door skin for a 69/70. I got a very solid on the underside but it looks like someone took a 1/2 drill and pulled out a dent with a tractor. I took out about a gallon of filler out of this door. I knew it had issues but ee gods.
thanks
pat
You can check with John Skinner jskinner1@msn.com
He is on here as jussmplcougars if you want to PM him.
I have done alot with John as far as purchasing, I will say he does not have anything, just the rear 69 quarters, wheel houses and front radiator support along with a taillight panel. Ill keep looking but hopefully someday someone will have 1.
Thanks
Pat
Decided to talk to a place here in FL that does restoration work and also collision work. I`m dropping the door off next week, he seen the damage and said they can fix it.
thanks
pat
