69 Cougar Eliminator dash emblem
Does anyone know who may offer the passenger side dash emblem beside the clock? it just say’s “COUGAR” not sure if it’s unique to just the Eliminator.
Thanks
Tom
I am not making it yet. Is this an item that is needed? The '67 '68 versions have done well.
I will keep hunting.
Thank you for the response!
The right side dash “COUGAR” emblem is not unique to the Eliminator. It is the same emblem that is used on all 1969-1970 standard Cougars. There are 2 versions, one is plastic and the other is metal. The plastic ones usually start to curl up on the ends and like most plastic emblems the chrome peels off. Most people prefer to find a metal emblem. There probably would be at least a small market for a good reproduction of this emblem.
There is a metal one on ebay right now - along with the standard dash panel.
Dash Insert w/ Metal Emblem - Standard - Passenger Side 1969-70 Mercury Cougar | eBay
Hello Tank, I have a NOS Std (woodgrain) passenger side dash fascia panel.
The woodgrain is damaged, but the Cougar emblem is perfect. The emblem would have to be removed and installed on your camera case fascia panel. If interested, I can send photos to you.
FMI, Please send a P-M or call / text: 765 - Six, Six, One - Three, Zero, Seven, Eight (Indiana).
Thank you.
Yes I am interested in the emblem.
Thank You
Thanks for the info.
Thank you
Randy where have you seen a metal version of this emblem? Original or repro? My 69 is an early January build and has the plastic. I would be very interested in a metal one. The one in the above eBay link is plastic. You can see the right side curling up.
You can see both the plastic and metal emblems on the WCCC website. The information that I have is that the plastic emblem was used for the 1969s and the metal emblem for the 1970 models.
I contacted the seller of this pass. side dash insert ( plus the Cougar nameplate ) and this was his response:
New message from: [cougar_xr-7_parts_and_more]:
Hi Gord - The nameplate is metal on the dash insert. Let me know if you have any other questions. Thank you! Brett
Is your’s metal or plastic, I’m hoping to find a metal one.
Sorry Tank was my cat’s name, I’m Tom
Thanks so much
My 69 Eliminator has a build date of 4/25/69. The car came with the metal emblem.
Yes sir :grimacing:
Hello Tom, The NOS dash emblem on the panel assy is plastic.
Sorry for the slow response… Had a busy week.
I would buy one. The edges on the plastic ones curl up and the chrome on the metal ones is not very good and is hard to find one that is not pitted up.
