I am rebuilding my Tilt-Away column as it would not tilt away.
In the process, I identified a few issues.
A snap ring is installed in front of the upper bearing.
No lower bearing
Wires pinched (Plastic sleeve missing)
Insulation in lower tube missing
Reputable sites indicate snap rings were not installed on the upper and lower bearings.
The trusted WCCC site states “Used snap ring that is used to hold the bearing on you the steering shaft. This ring was used on 67 - 78 fixed columns and 70 - 78 tilt columns. Not for use on 67 - 69 tilt columns.”
The upper bearing was actually held in place by a snap ring, The snap ring slips into a groove in the shaft aligned with the bearing. I removed the snap ring easily with a $4.99 a PITTSBURGH Snap Ring Pliers with Interchangeable Heads set from Harbor Freight. The bearing then popped right out.
The shaft would not push back from the lower bearing. Looks like I will need to remove a couple of pivot pins to get to the lower bearing and shaft joint.
CougarCJ, Sounds like you have much experience with these tilt and tilt-away columns. Could I lean on your expertise related to removing the shaft from the knuckle on my tilt-away. Looks like something is holding the shaft in the knuckle even though the front bearing is out. Am I correct in that I must remove 2 pivot pins to get the shaft out? Any advice would be greatly appreciated. The column is rock solid with zero play in any of the joints. I just need to get all the old, dried grease removed. It was stored away for many years. Thank you.
Yes, you must remove the two pivot pins. they can be very stubborn. I don’t have any tricks. 6-32 pin puller usually breaks the threads.
Have had to ground the head down and drive out the pin with a pin punch. You must be very careful, easy to damage the upper knuckle. Not much space to drive the pins without hitting the joint on the shaft.
I should have added a correction. The lower bearing is actually in the column. I incorrectly stated it was missing earlier. The column had never been previously serviced.
