I need some assistance with the installation of the rear floor pans for a 69 cougar convert. Do the pans install underneath or top side of the insterior? Where do the outside edges weld to? Any help appriciated! email me pix to rodney.r.krause@gmail.com thanx!
This is just a generic example, but it will answer a few questions. Remember… YouTube is your friend.
Ok floor panels installation, does the edge go under the frame rai where does the outside edge attached weld to?l
dual rockers on a vert. Inner ones is where the pan welds to. flange/bend has edge pointing down,
While this is a hardtop, the process it close to the same. Hardtops do not have the inner rocker that helps stiffen the chassis on your convertible, the floor panel fits the same area. As I have not done a convertible, the flange on a hardtop points up.
Floor pans weld onto the bottom of the inner rockers. Just put some patchs in my 69 vert last year.
