69 Cougar Shock Support - Rear - Transition panel
Looking for some help with the installation of 69 Cougar Shock Support - Rear - Transition panel.
I have the old one out and am looking for the best way to install the transition panel. I have welded and repaired everything that needs repairing so it is structurally sound again now what is the best way to install the repaired rear shock support transition panel?
I cannot figure out any way of welding, the inner tabs without tearing more of the car apart that doesn’t need to be tore apart. So if any of you guys have a good idea on how to install this, I am wanting to weld it back up, but there’s no way to get to the inner brackets that were welded on the inside of the support to the frame.
