We are now taking orders for our USA made power steering delete idler assembly for 70-71 Torino / Cyclone 429, 429 CJ/SCJ. Also correct for 71 429 CJ/SCJ Mustang and Cougar
This is a complete solution, including the DOAE-8A620-A engine bracket, D0AE-8A619-A pulley bracket, aluminum cylinder head spacer, pulley, adjuster bolt and 7/16" yellow zinc cylinder head bolt. Brackets are stamped with the correct engineering numbers for an authentic appearance. The pulley bracket is die stamped 1/4" steel and the engine bracket is die cast T356 heat treated aluminum
These are manufactured using CAD technology and laser measurements from original Ford components for perfect fit and correct appearance.
The pulley is a modern service part and does differ in appearance from the stock Ford D0AZ-8679-A unit. However - the pulley is easily available & serviceable should the need arise years from now
$599.99 shipped for the complete assembly, but individual parts are also available. You’d spend nearly $1,500 assembling this kit from used Ford parts.
Shipments beginning Monday on the first 15 units. Please PM or call 978-790-2658 for more details or to place an order
