Just got chance to post some picture of the same Bar. Did you use the ADDCO hardware Kit for install?
This is the ADDCO 1970 Cougar OE Style 5/8” Rear Sway Bar (P/N 02-614-00) and Hardware Kit (P/N HW2-2614-0U)
The Bar is 47.75” CTC Wide, 13.25” CTC Arm Length, with a 1.75” offset at the end of the arm. The bushing eyelets have a tapered hole starting at about 5/8” down to 35/64”. The Bushings have a shoulder just under 5/8”. So the fit in one end but not the other. The End Links are shorter than stock with what ADDCO calls 8” FH (Functional Height) The bolts are 3/8-16 X 11” with a square tube spacer that is 6” long, 9/16”OD, ½”ID. The End Link washers are flat rather than the stock cupped washers.
