8.8 parking brake cables
I’ve used the search feature, and haven’t been successful at finding what I’m looking for. Anyone have some good advice, tips, tricks, pics, videos on how to modify the parking brake cables on my 8.8 rearend that I just installed in my 67. Been messing around with cable routing, but thought maybe if someone has already been successful at getting them to work, I’d be glad to learn from your experience!
Thanks!
Were you able to find a cable or adapter i just installed 8.8 in my 68 and have the same issue, other than that it was a great swap
I for get what I used, but I removed both steel cables keeping the sleeves and put a long cable through both adding cable stops on one end. DO NOT CUT!!! I used 2 stops(brass) work the e brake some to stretch the cable, adjust the slack as needed, it helps having the extra slack to pull tight. now leave som e extra cable in a loop. as you use the e brake, you may need to adjust it later.
I found a company that makes cables to order. Choose ends & cable type even.
Control Cables Super nice guys!
