Do any of your other gauges show similar behavior? If so, it could be the constant voltage regulator, corrosion on contacts, corrosion on CVR input power line (it uses a resistor wire as well), or a poor ground.
Gauges read correctly with proper termination resistance. That said, your problem likely resides in the temperature sending unit itself.
Did you recently install it, perhaps wrapping the threads in Teflon tape (a no-no)?
I did change it out with one I got from WCCC (the one I took the measurements on). I’ll drive it around for a good warm up as soon as this rain passes and report back. I also noticed the wire was a bit loose so I crimped the connector slightly.
Perhaps this is a somewhat idiotic idea, but have you checked your thermostat or changed it? A new one isn’t that expensive. What about your radiator? Has it been flushed out lately? If something was stuck in your thermostat preventing it from closing, that could cause an actual lower temperature. So could one that is simply stuck open all the time because its tired and needs to be replaced.
Actually good questions. I’ve not changed the thermostat since I’ve owned the car (about 5 years). No idea when the radiator was last flushed. I’ll dig deeper if it continues to act up.
The thing that has me scratching my head is how it just changed between times I had the car out. For as long as I’ve owned it, the temp when warm was always just shy of half way unless it was really hot outside and I had the AC on, then just over half way. Suddenly it was just going up 1/3 of the way.
You can measure resistance from the post to the chassis of the sending unit while using a heat gun; at least you can see it go from about 70 ohms to about 13 ohms when it gets hot.
Yes, you put the Instrument voltage regulator on the positive side to supply power and the resistors you used before in between the ground and the gauge.
I would just test it at the harness where it is routed to the cluster from the sensor. Removing the cluster is a PITA.
You can test the thermostat with one of those thermometers you use to tell what the temperature of a turkey or ham is.
Just use a stove to get the water up to boiling. Drop the thermostat in and watch it as the water heats up. Use the thermometer to see if it matches the water temperature. For example, a 180 degree thermostat Doyle fully open when the water is 180 degrees.
