AC compressors what year?
I have a 69 428 that had AC and unfortunately it was removed. A friend will give me 3 compressors and I need to know what is the closest to my year or what they went to?
Compressor #1 Says Motorcraft No. YP 0617723 Pt. D50H-2875-A2B below that says 05-79
Compressor #2 Says FoMoCo Serial No. A59328 F68 B.M. No. 99204-1 Model HG 1000 Part No. C8AA2875A1
Compressor #3 Says York No. K 1170612 Pt. F209-16485 below that says 040
I will be needing the mounting brackets if anybody has them. :unamused: Thanks
#1 is out as nothing on your 69 originally said Motorcraft on it. Motorcraft parts were not put on until about 1972-1973.
#2 has a 1968 part number, possibly okay for your car.
#3 no idea.
If you consider the C8AA pump, look at the service valves. 1969+ used square O-ring connections. 1967-68 used a rounded compression fittings.
