Another Sequential Tail light Question
Hello everyone. I’ve read a bunch of the posts on tail lights and think rather than repair the issue just upgrade. So first question can you recommend a complete sequential kit for a 69? second question do these led kits require flashers and sequences or anything else? I really just want to replace everything mostly for safety. any help would be appreciated.
You will need to diagnose the current problem to make sure you don’t still have it after the upgrade. Once you know the upgrade will fix the problem then go for it.
ok. any idea where to start? I signal left or right and said side lights up. all three brake lights. no flashing. no sequential. just solid like brakes are on. hazards same.
Pleas refer this thread. It wil answer ALL your questions!!!
Since all three bulbs light solid on both turn and hazard, the problem is likely upstream of the sequential motor—often the turn signal switch or a bad ground rather than the tail light unit itself. Before buying an upgrade, confirm whether the switch is sending the correct signal. The troubleshooting thread mentioned above is a good place to start, as it walks through isolating the switch, motor, and relays step by step.
