Can someone post a picture of their set up for an alternator on a 351c? I would much appreciate it. I want to make sure I am buying the right parts for the set up. I found the main bracket and spacer but I think I still need the mounting bolt, pivot bolt and adjustor arm to attach to the water pump and valve case. WCCC has the items I just want to let everything in one shipment. Thanks for any help
Hard to see much, but here is the top bracket and long bolt that goes through the spacer to the engine. The bottom adjuster bracket can barely be seen, but it is attached to the bottom bolt of the top bracket.
Calicat, thank you. It is tough to see that adjustor bracket but I get the idea. The spacer is positioned between the valves/block and the alternator, correct? What year is your cougar? Your main bracket looks different than the one I have
