Both indicator lights come on signaling right or left
Emergency Flasher also light both lights on dash, All outside lights are working fine. I replaced the flasher with the new style. I don’t remember if it did the same with the old one. Guess I will have to find it. 1967 base Cougar
1967 uses two flashers under the dash. I think Vic Yarberry can tell you which one needs to be replaced.
I see 3, but at 70 finding it hard to get under there. I think I will take the seat out. If some could identify the screws I need to remove to take the whole plate off. Thanks
