Is there a way to test a booster when out of the car? I pulled the master cylinder to bench bleed and found some fluid in the booster. My symptoms point toward it being bad but I’d like to be sure before I send it out.
As far as I can tell brakes worked fine for the year plus I’ve owned it. Few months ago I decided to upgrade the front suspension and after seeing the brakes I thought to replace the factory front disc setup. Got it on the ground and had hard brakes and Ford manual testing makes it sound like a bad booster. Either the MC had been leaking into the booster all along or the 3 months on front stands caused the issue due to angle.
Yes you can bench test it. Try one of your search engines for info.
www.google.com/search?client=firefox-b-1-d&q=how+to+bench+test+a+brake+booster
Thank you
Got it pulled and verified it’s bad. Thanks again
Wasn’t that fun! ![]()
Ha! Probably the most awkward and spine bending part I’ve messed with on this car ![]()
When you put it back in, pull the drivers seat, 4 bolts, you can lay on your back with your feet in the back seat.
Great advice thanks
Unfortunately I didn’t take your advice and I’m pretty sure I bruised a rib or two….
Good news is the cougar is back on the road after a few months of upgrades
