I’m having a small issue with the “C” pillar lights in my '68 XR-7. They won’t turn off.
Looking at the wiring diagram, it appears that they are supposed to turn on/off when either door is opened/closed. Is that correct?
They also turn off with the Courtesy Light switch on the dash.
Also if you have the headlamp switch rotated all the way counter clockwise they would be on all the time, or if one of the door switches is not closed.
This was the problem. The wiring diagram doesn’t show the switch on the dash.
Thanks!
