i want to change my rear shock absorber into highjackers. does anyone have an instruction to change it ? the lower screws are no problem… but i think i have to remove the backseats ? i dont saw any screws or something…
can you help me…
yes ,… but how to remove the backseat… i try to raised up… but it doesnt comes out… if i try it with more force maybe i damage anything… are there screws ?
Your avatar looks like you have a vert.
You may want to remove the chrome well piece from the top of the back seat.
Push the front of the bottom seat cushion back. In the middle of each side there is a catch in the floor. Once the seat is removed there are 2 nuts that hold the back in place at the bootom of the back. Take these off and lift the seat straight up. It should clear the chrome strip on the back. It only has to move a little bit and will release.
