I’m thinking of getting this kit SK31-216-2 (cam/lifters/timing set) for the Cat. It’s $231.07 with free shipping. What do you guys think?
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=791&sb=2
After reading some of your previous posts, You mentioned a Beat Lifter. This is usually caused by Either Oil starvation (Sludge in the Oil Passages), or excessive pressure (Valve Lash Too Tight). If the Damage Wiped the Cam Lobe, The Chips end up in the Oil-pan, And The Oil-Pump is the First Victim!
The Failure Cascades. I Would Investigate the reason for the failure before attempting to repair it. ![]()
