Complete power steering system taken off my 68 Cougar. It’s a running and driving car so it works as it should with no leaks. Simply converted over to an EPAS system instead.
There are some upgraded parts or rather the better option parts on this system. Included are the big block reproduction pressure hoses and mount that run down and alongside the engine making a much cleaner install compared to the small block version. These are like new and only installed for a short time. Also updated the pump reservoir to the 69+ style so the return hose points straight down vs the earlier versions making for a cleaner hose routing.
The pump, ram and control valves are reman units and function well without leaks. Frame mount for ram and power steering bracket included.
Asking $350 for everything, located in Phx, AZ, would prefer local pickup but could ship as well
