I have a case fill, c4 ,26 spline.
351w .
Cant get the proper gap.
1/18 to 3/16
The converter is couple sheets of paper off the flex plate.
Straight edge across the bellhousing
To converter face , should be 1" to 1" 1/8
It’s 7/8 .
I’ve pulled the converter 3 times and put it back.
It’s all the way back.
All 3 times, same measurements. 7/8 .
What is the issue. ?
Flex plate is from scat . 157 tooth 28.oz
Converter is a tci street fighter.
Good parts I think.
I’ve called both.
Scat says it’s the tci converter and tci says it’s the flex plate .
How do I get the 1/8th min to the 3/16 I need. ?
