428 going back together. They are tied up with a problem child big block chevy today and tomorrow then you should be going together. Everything SHOULD be here now
The sequential setup working is the part I’d want to hear more about — are you logging it alongside the fueling data, or are they separate logs? Curious how you keep the runs comparable when cruising around Findlay versus other routes. Even small changes in route or stops can muddy the numbers, so I’m interested in whether you note conditions per fill-up or just track totals.
Mainly I was trying to diagnose engine tick and over heating issues. Plus mileage and other things. Did determine that he was getting 12 mpg. Pretty good for a 428CJ with 3:35s!!!
The electrical side usually comes down to checking grounds and voltage drops before replacing parts, especially on older harnesses. For carburetor issues, a vacuum gauge and a timing light often reveal more than swapping components. Are you logging the data manually or using a meter with recording? Knowing which circuits are intermittent would help narrow things down.
I wish I could get that in depth. Thunderhead289 on YouTube does great job going down those diagnostic avenues. Would LOVE to do THAT someday. But right now just videos and manually writing data down.
Just got this from Bob McVay. Holy Crap. I’ve inquired twice… TWICE. And by email ONLY!!! Haven’t called, showed up at his doorstep??? WTF IS GOING ON???
Ahh, new flooring, BTDT.
