Door Ajar Low Fuel Brake Light?
My car has these but I don’t think they work. Anyone have a picture of them lit up?
The brake light works also. Just don’t have that photo.
Thanks. Mines an XR7 so the lights are in the gauges not on the ceiling. That’s what I’m looking for pics of.
The picture he posted is also of an XR-7 so maybe yours is a different year? Easy button is to put your car (s) in your signature. Then you won’t ever see this question again.
It is in my sig. Does it only show up for me cause it’s at the bottom of all my posts? 69 xr7. Lights should be in the gauges I believe. Parking brake light should be in tach. Low fuel in left pod and door ajar in right pod.
Yes! I don’t have any '69 pics though.
The 69 & 70 xr7’s should be set up in the gauges - but basically they will light up red if activated. If I remember they should also blink on briefly when 1st started. Door (open) & (parking) brake should be real easy to test… Fuel tells you when you are down to a gallon or 2 in the tank - don’t recommend testing that unless you have a can of gas to add when you run out. This also will blink on/off as you turn sharply or accelerate - tank is pretty flat so the gas will slosh around “fooling” the sensor
I’m pretty sure none of them work. Not even sure if all the components are there to make them work. Didn’t even know it had these lights till just recently.
I went through a bunch of the same problems a while back. You might read through this thread and see if it helps you out any…
https://cccforum.discoursehosting.net/t/indicators-buzzers-and-warning-lights/5826/1
Did the 69s have the buzzers or just 1970?
If none of the lights work where’s the best place to start? How do you know if you have the deluxe belt group that would have the warning light for that? Also what is prove out? I’m guessing 69s didn’t have the key buzzer or lights light/buzzer?
All '69 XR7’s had the low fuel and door ajar warning light.
Black, dark blue and nugget gold were available in both standard and deluxe, but if your original seatbelts are a different color then those they are deluxe.
A Marti report, Eminger invoice, window sticker will tell you if you have the deluxe belt group.
Prove out is the initial check of the system when you first turn on the key.
The buzzer did not come into use on a Cougar until the 1970 model year.
Has black belts but not listed on window sticker so 1 less light to worry about. If it’s bulbs which is doubtful can they be changed without removing the cluster?
While nothing is impossible changing the bulbs without removing the cluster is not easy. And if your car has factory A/C that will double the not easy factor. The amount of time and aggravation you will spend trying it would be far better spent just removing the dash pad and then the cluster. The first thing that I would look at would the exposed section of wiring that comes out of the hinge pillar and then goes into the front of the door shell. That wiring is very often damaged and/or cut. Inspection that section of wiring for damage.
Lights don’t work because there’s no circuit for it. I don’t have the wiring diagrams for the car. Would it have had a separate harness for these lights if so how difficult would it be to wire back in and get them to work? Where can I find the wiring diagrams?
You don’t have any wiring associated with the convenience group lights (door ajar, low fuel, brake,etc)? That’s tough; the basic wiring is typically integral to the XR7 underdash harness and one needs extensions for the overhead lights ; for Mustangs, they were almost always in the dash area and used a separate harness for picking up the various devices. For Mustangs, these convenience harnesses are fairly rare and in high demand (i.e. expensive); the lights and proper covering lenses even more so.
All lights except the warning lights work. Expensive and complicated is likely why it doesn’t currently have them.
Most all of the wiring for the warning lights is a part of the main wiring harness. If your car is a true XR-7 and has the original wiring harness in it then you will have the wiring you need for the warning lights. Let’s look at each warning light one at a time.
First the park brake warning light. I can see in your photo that you have the sensor for that. It is the white piece on the right side of your photo and it has a wire connected to it, so you have that circuit. Have you tried the park brake? If not push it on and then with the car running see if the light comes on.
Next the door ajar light. Did you check the condition of the wiring running from the door hinge pillar to the door? If not open the doors and look at it. If it is damaged, and many are, that may be your problem. If there is no visible damage you can next check to see if all the connections are still connected. This section of door wiring harness will attach to the main harness just inside the hinge pillar. If you open your doors do the courtesy lights come on? If they do not that may also be sign that there is damage to the wiring or that something is not connected. What condition are the door jamb light switches in? Do the plungers move in and out freely? If everything listed so far is good then you will need to remove the door panel to get inside the door. Once inside you can see if there is a single wire going to the door latch. Inspect the condition of that wire and make sure that it is plugged onto the door ajar sensor. If everything looks good pull a door shut so that it is only on the first latch and with the car running see if the door ajar light comes on. It should also be on with the door hanging wide open.
The low fuel warning light. The wiring for this is a part of the XR-7 harness. This wiring runs under the left door sill plate and will then come out inside the trunk. There will be a separate plug that will go down through the trunk floor to the sending unit. You can inspect that wiring for damage. If all looks good then you will need to get under the car. Inspect that the wiring is connected to the fuel sending unit and that it is the correct XR-7 style unit. A non XR-7 unit will only have a single post connector on the unit. The XR-7 unit has 2 posts. Check for condition and that you have the proper parts. It is not uncommon for the low fuel sensor to go bad. If that is the problem you can remove the sending unit from the tank and send it to Bill B to be rebuilt.
Now go do those checks and tests and tell us the results.
Hmmm… Better make sure your car is a real XR-7, or that someone didn’t hack your wiring harness at some point in the past >.<
How would I make sure it’s a real XR-7?
