When I open the door it automatically wants to spring open a couple inches…is this normal? I put in new hinge pins and bushings
Recent door seal gaskets?
Yes 2 years ago with doors left shut…however the passenger door is perfect…thanks
My $.02, Window is out of adjustment. do you have to slam it to get it to latch shut?
Mike M.
No slamming necessary shuts beautifully
Thank
Question, does it do that with the window up and down?
Both up and down no difference at all
That rules out my thought.
And mine
Mike M.
…still could be the repro A-pillar weatherstrip that extends down in front of the door. These were too stiff resulting in the door springing open like that.
I removed the weather strip and still the same
Huh, well I’m all out of ideas now too. Assuming you have good sheet metal clearances all the way around the door, seems it about has to be something wrong in the hinge itself.
