Does anyone know if FMX and T5 transmission starters are compatible?
I highly doubt it. The distance to the flywheel (length of the starter nose) is usually different between a manual and automatic trans.
I’m not positive, but I think you do use and auto starter w/the T5 conversion.
I’m trying to find a mini starter to put on mine. My headers are roasting the factory style
You can get a Power master mini that will index to clear headers. Just don’t buy the $150 cheap version. Go the next step up which is heat resistant. Can’t tell you what model will fit your application. Might have to call them.
powermaster has 289/302/351W all as the same starter.
