I have a 69 cougar with a FMX transmission, I have no Drive just 1st and 2nd so I need a rebuild. I want to increase the HP of my motor to about 500. I dont know if I should put the money into this transmission or swap it out to a C4 or something.
an FMX will hold 500 if built properly. However, it’s not popular and finding someone to build it might be the hard part. A C-4 might be your best option for drag racing. Or, you might want to consider an overdrive trans.
Not many parts or builders available for fmx. C-4 has many parts available to handle 500 hp easily. However. If this is ever going to see highway use, get and overdrive auto or manual
I agree, not much out there to support the fmx. If you do swap to a c4, lots of companies build a bullet c4. You will have to change your drive line as they’re different lengths between the two.
C-4, FMX and AOD should all be 30 1/8 OAL.
FMX to C-4 or AOD you will need a 28 spline slip yoke. (FMX is 31). I’ve changed from FMX to AOD and only changed the slip yoke reusing the FMX shaft. Some people have reported needing to shorten the shaft.
David, where are you located?
Ontario Canada
If I go with an overdrive tranny is a C5 the choice and what year?
What about the linkage, will it work and will the center shifter have the range to work properly?
For overdrive look for an AOD which can adapt easily to the stock shifter. You would want the AOD rebuilt and if pushing 400 hp likely would need special upgrades. I have an 1987 Mustang AOD in my 68 using stock shifter and 3.55 rear gears. I run in 3rd gear for 2 lanes and drop into OD for interstates or long flat stretch’s. Did need a shorter driveshaft. For high horsepower the later AODE might be a better choice.
If using higher horsepower, I think the 4r70w gear ratio is the choice
