I’m looking for a fmx trans? I’m in NE Ohio!
I have several here in PA. If you are coming to the Spring Carlisle show I am not very far from there.
I have a big block auto here. If I recall when I bought it I was told it came out of a 69, but it was a long time ago. What makes it a fmx?
This one has (had, it is broke) a yellow dipstick tube. I have torque converter, spacer plate, ring gear, and an auto drive shaft with yoke.
Can get you numbers if it qualifies.
David
The FMX transmission is a cast iron main cast transmission. The big block transmission you have 8s most likely a C6. It is aluminum case unit. Also the FMX has a bolted on bell housing and the C6 is cats in to the main case.
Thanks Neal. Useful info. Some day I need to get this thing out of here.
