I posted this on the other site also, but I need all the exposure I can get.
I left my car outside Sunday and part of today under a car cover, when I removed the cover, the paint had blistered on the spoiler only, now with Carlisle less than two weeks I will have to strip and repaint, If anyone has a spoiler decal left over from a clone build, I would love to buy it. Please PM me if you can help. Thanks ![]()
Found one, Thanks
What is your spoiler made of, Fiberglass? If so, the blister may come back if not repaired correctly. Once you take down the blister and you find a pocket, fill it with fiberglass resin, not body fill. Once filled and leveled , you can go about the rest of the body work to repair it as normal with other fillers. I found out the hard way on a Vet, I used regular filler on it to start and the blisters kept coming back bigger and bigger, once the sun hit it.
Carlton has an original E-cat spoiler I believe.
Yes it is original, and it’s made out of some type composite material like Plastic. Well for now it’s been stripped down to where the blisters started from, and I gave it a coating of Icing then hi-build primer, base/clear and now it is drying in the paint booth as I speak. Hope for the best! ![]()
On this subject, since the side and hood stripes are matt black, should the rear spoiler be the same, or gloss black. Most makers of these have them in gloss.
