I’m in the process of adding new LED headlights. I have read about and watched YouTube videos how to adjust the low beam lights. You want to ensure the cutoff line is low enough as to not blind oncoming traffic. Haven’t found much about the high beam lights. My question is do you aim the high beam lights the same way you aim the low beam lights?
Basically the method and numbers he outlines are based on being 25 ft. from a flat wall on level ground. The low beams are the most important to get right. Your high beams should basically be aimed straight ahead - no upward or downward tilt.
