I put the engine back in the GT-E last week and fired it up over the weekend. It fired right up and ran real good. I had a few water leaks where the tower clamps were not sealing on the bypass hose at the waterpump.
I drove back home and put some new style clamps on to stop the bleeding. I went for another test drive once the leaks were fixed, about 5 miles in the car started to run poorly especially at steady speeds or idle.
I drained the gas tank and put in 5 gallons of VP 110 octane since the car had been sitting for a while. I also used carburetor cleaner. It ran better but not perfect and then got bad again upon the next start up.
Turns out it is steadily leaking gas into the intake. I adjusted the front float down and got the car to idle and then started adjusting the float upward but before I saw gas it seemed to start running poorly again. I backed it back down a little and locked it (rain is on the way and it was late, had to get it put away). It ran better on the way to the shop but now it seems to starve for gas on acceleration and its still not perfect on steady speeds but is much better than it was and no more gas running into the intake.
I’m going to work on it more tomorrow and wanted some input since I know little about setting a carb properly. This carb has been on the car the 10 years I’ve had it. It may just need rebuilt.
To make things worse when I went to put my correct and restored GT-E carb on it one of the bowl inlets was stripped and that carb is inoperable until I can find another rear bowl to replace it. So I guess that when it rains it pours as the saying goes.
