7A2 is a known date code but I’m not sure what the 7LB is you’re referring to.
7LB would be the tag code, they decode different than the air horn stamps.
If you check the photos I posted the air horn is 781 but the tag is 7HB
7A2 and 7LB are both 2nd week of November 1967.
My GTE is a May build and has a 7A2-7LB carb on it. It is the original carb.
If you check the photos I posted the air horn is 781 but the tag is 7HB7A2 and 7HB are both 2nd week of November 1967.
Didn’t realize that. I haven’t seen many original tags. Thanks for the explanation.
Yes it is the tag code. The reason I posted was so people could see the span between the carb dates and the car build date.
ok i got my 2 carbs out
carb1
airhorn c8af 9510-ad
list 4088
date 7A2
tag c8af ADA 7LB
carb2
c8af 9510 ad
4088
date 962
no tag
Post some photos so we can see what condition and if all the parts are there.
The first one 7A2 is the most common production date.
The second one 962 is a 1969 replacement carburetor worth far less but still worth something.
carb1
list 4088
date 7A2tag c8af ADA 7LB
carb2
c8af 9510 ad
4088
date 962no tag
im posting pictures on the GTE facebook page its easier then doing it on here.
carb1
list 4088
carb2
c8af 9510 ad
4088
date 962no tag
Any feel for the value of the service replacement carb? I have one that is sitting…
I would like to enter the lottery or get my name in the drawing for a C8AF-9510-AD 4088. I just picked up a GTE “W code”, that has a 23B build date. The engine, trans and rear end are numbers matching. I am missing the correct radiator and shroud as well. Sounds like the correct 600 Holley is a bit of a unicorn hunt. Not sure how far down on the dance card I am but I would like to be considered if one comes up.
i have 4 of them.
All 7A2 code, all with correct metering blocks.
All fresh professional rebuild
PM please
I sent a PM with my cell. Look fwd to hearing from you.
Thx again for the reply.
