I got a real bummer a couple of weeks ago…my headliner in the pristine-interior’d Standard has a mouse chew-hole in it… I’ve stuffed a dryer sheet up in there and have since put out (more) bait and traps. There are some real down sides to living out in the middle of grass fields, argg…
Anyone got a suggestion to patch it up in a way that doesn’t look ridiculous?? Thanks!
I have the same issue, but its also the original headliner - no mouse but the whole thing is dry rotted luckily its a small hole.
Its in a spot right in between the sun visors must have used one as a spring board - I jreally just need to replace the whole thing so Id be interested in peoples answers as well.
I didnt use a dryer sheet - I just brushed out one of the cats and stuffed some fur up there - also put enough (for a kitten) on the bottom of both corners of the garage doors
