I need a 1969 Cougar drivers side door
I need a 1969 Cougar drivers side door.
FYI, if you don’t know already a 70 door is functionally the same. I am unaware of any difference other then date codes stamped in to it some place.
2 holes for door plate, where 70 has no holes due to tag being a sticker.
Also helps to know where you are located
Yes, where are you located? I have one or depending on where you are someone here can point you in the right direction.
It is for a 1969 Cougar convertible and I am located in Montreal, Canada.
Thanks, Brian
