Hi people!
I´m installing a new radio to a 1969 Xr7. Just need to know to what wire from the ignition switch I´ll connect the radio´s eletric feed. I mean the wire´s color that corresponds to the ON POSITION.
Tks
Hi people!
Tks
You’re better off tapping into a fused line instead of ignition lines. Try the Blue/white cigarette lighter wire for memory save. There should be a yellow/black wire that was originally radio power (ACC) that is for the radio itself. Both wires are fused.
Hi,
it worked just fine I conected to the cigar wire ( blue and white) .as you said. Now I can listen to the group Eagles while cruising. Tks so much for your help
