It really is simple.
When talking coils we are talking stock style canister coils. Coil packs, GM HEI coil in cap and modern (post 2000 to be safe) coils are NOT included.
You have OEM (original equipment or ‘stock’) and Aftermarket (Pertronix, MSD, Accell, etc).
All of the OEM coils are made to be used with an external ballast resistor - be it ceramic or a resistor wire. FoMoCo (Ford Motor Company) chose to use the resistor wire in our cars. The general rule of thumb is the input voltage at the coil is about 1/2 the system voltage.
This is fine, but current through a conductor = heat and heat = resistance so in very high RPM situations the input voltage could drop and cause misfires.
One solution was create a coil that would accept full battery (b+) voltage (commonly called 12V). These coils are not widely used in street applications and will not run well with reduced voltage.
The most common aftermarket solution was to reduce the normal internal resistance from 1.5 ohms to 0.7 and in some cases 0.3 ohms. These coils also have more windings and the good ones use heavier gauge wire as well. The lower resistance and additional windings result in a higher voltage discharge or spark.
Most OEM canister coils are marked as requiring an external resistor - like my OEM Duraspark coil is.
ALL coils requiring 12V should be marked as NO BALLAST coils and NOT include a ceramic ballast resistor. A 12V coil with a ballast resistor will run like crap - especially at idle.
Last I knew Pertronix coils came with an external ceramic ballast resistor. I believe that they do this because their products are designed for performance vehicles that probably do not have the original ballast wire anymore. It is up to the end user to decide if they need it or not. The fact that it comes with one tells you that one is required somewhere in the circuit. If in doubt, ask the manufacturer if they supply or recommend an external ballast resistor with their coil.
So, unless you are running a high performance aftermarket (or late model OEM or GM HEI) coil, you don’t need 12V to the coil input.
Now, for the IF:
IF your OEM resistor wire has failed or someone has removed or bypassed it, you will need 12V to the external ballast resistor that is normally mounted beside/with the coil.
As far as the Pertonix Ignitor: All three SHOULD have 12V. Some folks swear that connecting a series 1 to the coil + post works fine and they might, I don’t know because I have never wired one that way.
