Greetings!
Trying to figure out the difference between these two versions of harness so that I can properly advertise them for sale. Found them in a box…..fairly unmolested along with a really molested one…..but salvageable!
I have one with a Red Tag and C7WB-14401-L and two without tags that appear different…..one has a blue piece of tape in the middle of where the cluster would sit-ish. Other one, not sure….
However the only difference that I can find is: on the RED TAG -L harness, it is lacking one lite blue/red stripe female red round plug wire that appears on the two other harnesses, about 3-4” from the fuse block. Short wire with a round Red female connector. I also couldn’t determine what it is for……cluster lamp of some sort??? Dash panel???
(I have no XR7 wiring diagrams of harnesses at this time but have Electrical Assembly Manual on order.) Managed to figure most of this out except for the one wire above and two connectors below…..
The other issue is being unable to identify two connectors on the LH side of the wiring harness along with all the connectors that go to the front of the engine comp.
Both are three wire connectors, BLACK connector has Male Black with Orange or Red stripe, Male Orange with Green stripe and Female Green with White stripe wires, and a BLUE connector has Male with Lite Blue/?, Female with Black, and Female with Orange with Black stripe wires.
I’m guessing that these two connectors belong to something heading to the rear of the car, however I have no harnesses left to run down the left rocker panel!
Thanks for looking!!! Hope I can find some sanity here cuz I’m going crazy chasing wires…..
Cheers!
Steve
Blue/Red (teeny tiny stripe) wire…..unique to this type of harness….. FOR WHAT???
It will have a round red female connector on it. This one has been removed for some stupid reason……take away his wire cutter…….
Blue stripe on middle of harness aprox in middle of instrument cluster. Positioning aid for assembly or identifier? No tags remain. ![]()
