I have located a good red instrument panel circuit board for the Eliminator. The only issue is that the copper tabs that contact the plug have lifted from the backing sheet. This problem has given me issues before when the tabs move and don’t align with the plug
Does anyone have any recommendation on a type of glue they have used that will successfully stick the copper tabs back down on the backing sheet (or what not to use because it didn’t work)
Leon,
I had the same problem, a small dab of super glue on the back side held the tabs in place, after glue dried I brightened up the copper strips with a fine scotch brite pad.
Thanks - worked great. Also discovered the little windows in the back of the instrument panel / circuit board that allows you to check if the globes are all working before you re-install the panel
