It’s been awhile but I have finally started the build up a 427 side oiler that I will be putting in a 67 XR7. I have a Robert Pond block, Edelbrock heads, the rotating assembly, and will be working with Lykins Motorsports for the cam and valvetrain.
I have been going back and forth on the induction system between EFI and duel carbs and I think I have decided on the 2x 4bbl (they just look so nasty!)
The only intake manifold that I have been able to find that will take the duel Holley carbs is the Trick Flow unit. The problem is this seems really tall at 6.6 inches.
https://www.trickflow.com/parts/tfs-56400114/make/ford
Has anyone with a BBF FE used this setup in a 67 Cougar and if so will it fit under the hood. I intend on putting a GT/E style hood scoop (because it look great) but just for looks (wasn’t planning on cutting a hole in my hood).
Update… I have been told to also look at the Blue Thunder medium riser manifolds but have not been able to find any in the 8v configuration.
Any and all recommendations are welcome and appreciated.
Thanks
