More progress today… Forgot my phone so no pictures… Will get some next week…
So, a quick narration of what I did today…
Removed center console, disassembled and gave it a bath in dawn and warm water… The console is in really nice shape as far as the plastic is concerned… One little chip at the front passenger side of the main piece and the insert needs to be replaced…
Removed the headliner… Bows look good and minimal surface corrosion on the inside of the sheet metal roof…
Remove dash pad and disassembled… Put that pad aside and got my better pad out of storage and cleaned it along with all the other plastic parts that are on the panel…
I have three XR7 clocks, going to send all three to WCCC and have them make me a good one… Hopefully they will take the other two for partial trade…
Remove instrument cluster… Noticed that someone hard wired the amp gauge while taking it out… One of the tracers on the blue circute board is bad to the gauge, hence the hard wire… Have a spare XR7 panel so I got that out of the other car… That panel is a red board but the tracings look good… Any problem running a red panel in the car…?? I would have to completely rebuild the spare panel since a couple of the gauges are broken…
Removed a lot of the miscellaneous door seals, interior trim around the windshield, rear shelf cover, sail panels, visors and just a bunch of little things…
I’m too the point now where I need to start taking lots of pictures so I dont forget how to put it back together…
Also, anyone know the size of the torque screw bolts that bolt the seat belts down to the floor…?? I do not have one big enough and would like to just buy the one to use with my socket wrench and not a whole set…
I also did a few things to the outside of the car while I was there…Removed tail light housings, rear marker lights and rear fender extensions for painting… Removed the trim for the vinyl top… Also removed the trim from the trunk lid…
Anyways… Pictures later…
Brian
