1967 cougar
289 C4
I’m cleaning up some wiring items on my cougar and was curious the function of the interior floor lights.
There is a light and each side triggered by the door switch.
Question is:
Are both light supposed to illuminate when you open either door or is each bulb individually switched with the the door on that side?
Thanks
Mark
Both lights should come on when either door is open along with the rest of your courtesy lights.
Ok. Thanks for the reply. That’s what I figured. Doors are off so I only had lower interior lights for testing. Someone cut some wires so trying to sort it out. If someone has the wiring diagram for interior lighting please post.
Thanks
Mark
Figured it out. I was missing the black/blue strip wire and connected driver to pass side with bullet connectors.
