The headlight switch provides power for all of the interior lights. Easiest thing to check are the 2 fuses in the fuse box,
2.5 Amp fuse in the middle of the fuse box. Note this is powered On when the headlight switch is in the Parking or headlamp positions. Feeds power to the instrument panel cluster lights, ash tray light, tachometer light, radio light, transmission selector light
7.5 Amp fuse to the middle right. Note, this circuit is powered On in all 3 headlamp switch positions. Feeds power to turn signal switch to power brake light switch and horn.
The headlight switch contains the following slots:
B – Battery, input circuit 25
R - Rear Taillamps, output circuit 14
I - dash illumination (*rheostat controlled), output circuit 19 to fuse box 2.5 A fuse, feeds power to instrument panel cluster lights, ash tray light, tachometer light, radio light, transmission selector light
P - Front Parking lights,output circuit 11
H – Headlights, output circuit 15, note routes to the dimmer switch, the dimmer switch then wires to the hi/low beam headlights
A - Brake Switch power feed, output circuit 10/460. Note, this circuit is powered On in all 3 headlamp switch positions. Feeds power to turn signal switch to power brake light switch and horn.
D1 - Courtesy Lamp Fuse, output circuit 54 to fuse box 7.5 A fuse. Note, this circuit is powered On in all 3 headlamp switch positions. Feeds power to the dome, courtesy, map, glove box, trunk, clock and seat belt warning lights
D2 - Courtesy Lamps, output circuit 53, note feeds all instrument, both door courtesy lamp switches, C pillar lights
Disconnect the headlamp switch and place a multimeter in Ohms mode with one probe in the B slot and the other probe in the slot being tested. Verify the truth table probing all of the slots with the 3 various switch positions.
Below is a “truth table” between the B slot (battery) and the corresponding slots:
Switch Position |
R |
I |
P |
H |
A |
D1 |
D2 |
Off |
Off |
Off |
Off |
Off |
On |
On |
Off |
Park |
On |
On* |
On |
Off |
On |
On |
On |
HD Lamp |
On |
On* |
Off |
On |
On |
On |
On |
*When testing the I slot (dash illumination), and the switch in Park and Headlamp position, turn the headlight knob clockwise and counterclockwise to see if the resistance changes. Counterclockwise will increase in resistance (causing the dash lights to dim) and as you turn the headlamp knob clockwise, the resistance will decrease ( causing the dash lights to become brighter). Turn the knob all the way to the right to the detent position and the resistance should be at its lowest value.
