Need a starter C7AF-11001-C a core for rebuild is ok.
Radiator C8ZZ-8005-C
Converter C8OP-7902-A 53 or if you can point me to a stock replacement. It needs to be one that is a direct replacement. I don’t want to get burned again on something that’s supposed to work but doesn’t.
If you use a stock torque converter be sure that you can use a camshaft similar to the stock one. The torque converter and the camshaft must match one another or poor drivability results.
Based on your knowledge of the Comp 268h, will a stock converter work? I’m making the mistake of assuming since it’s close to a stock cam that it would be compatible.
The ‘69 date doesn’t excite me since ideally I would need something before Aug ‘67. But I’ve learned I’m going to have to live with the wrong dates for the most part.
