Finally, there is some more activity on B3Cat. I had taken it out for an exercise run and it ran incredibly poorly, so I sent it back to Dave for remedial work. It turned out that the Edelbrock carb itself had something preventing the idle circuit from working properly so Dave cleaned the carb out and got it running right again. He also discovered that the plate inside the distributor that the Pertronix mounts to was loose, so that was retightened. While he had it in the shop, he did compression testing and all cylinders showed readings in the 160-165 range.
A couple of weeks ago, I purchased one of the electric headlight conversion kits, so that got installed as well. So there is no more vacuum to the headlights. I’ll have to test the actuators and see if they hold vacuum.
B3Cat ran really well all the way home, although like BBCat, the 390 doesn’t like hot restarts. Has anyone else experienced that problem and solved it? I didn’t notice any wandering on this ride home so I think the wind was a factor last time.
This Cougar has a 3.00 traction-lock rear end and I have noticed a clunking sound from the rear during low speed maneuvering, especially when I’m turning. Is that the trac-loc doing its thing?
Anyway, I will be driving B3Cat back and forth to work for the next week to continue the shake-out process and see if anything else pops up. Come next Sunday, my wife is planning to drive it to the Mustangs Unlimited show that the New England Cougar Club is putting on, so that’s about an hour of driving each way. I want to make sure the car is in good condition to get there and back with no drama. I’ll be in BBCat, so I don’t want either car sitting on the shoulder even briefly.
The next planned improvement is new wheels and tires because I get some squeal from the ones that are on there and I suspect they may have some dry rot going on. B3Cat will likely get the 15" Cragars from BBCat while BBCat goes back to stock Cougar 14" styled steel wheels and 235/60R14 BFG T/A’s.
Other than wheels and tires, the plan now is to just drive the car and rebuild the restoration fund for the body, paint, and exterior trim.
OK, so I stopped by my friend Dave’s tonight on the way home from work. After some discussion and another test drive, we concluded that B3Cat has a shift kit installed and the clunk is the transmission dropping back into 1st gear at times. I had noticed that the shifts were very firm on this car and it will chirp the rear tires on a 2nd gear shift without even trying, so it makes sense. There is a lot that was done to this car that we don’t know and Glenn didn’t know so we’re discovering it as we go along.
I also learned that Dave experienced the slow cranking on a hot start while the car was in his care last week, so Bill’s information above is very relevant. Now that I’m driving B3Cat, I’m starting to get some front end squeaks from the control arm bushings. A new to-do list is taking shape very quickly but that’s what this summer was intended to be about so I’m not at all unhappy. Even in its present condition, B3Cat drives straight and solid and runs like a scalded ape!
It does appear to have a drinking problem, though. Today’s commute was about 65 miles round trip and the gas gauge suggests that half a tank of $3.99 premium gas was consumed in the process. I guess I’ll know better when I actually fill up again tomorrow.
My wife has decided that B3Cat should have a white interior like Scott’s XR-7G. So that means (ideally) I need a set of white XR-7 door panels, a set of XR-7 rear panels, a set of white kick panels and a white console. Seat upholstery will be replaced anyway with new, as will the headliner. I can buy outright or include a trade of the dark blue interior pieces (console and kick panels) that are in the car now. The door and rear panels may not be any good; they are covered with trim shop panels at the moment.
I’m looking for Grade A, as Don would say. I don’t mind having to refresh but I’d prefer not to have to restore. I also have a complete set of black panels but I prefer not to have to dye them white.
The plan for B3Cat is now pretty well set.
The color will be changed to Madras Blue with a white vinyl top. The interior will be parchment with aqua carpeting. I just ordered a full set of new vinyl upholstery from JCC in parchment and previously purchased all the other interior bits from Randy. The interior bits are at Seamless Customs, where they will be completely refurbished to look new again.
Once I receive the upholstery from JCC, those will also go to Seamless Customs, where aqua running cats will be embroidered into the top front of each seating position. I still need to order the headliner, and will need to find a parchment console/clock pad but there is still plenty of time for that. Worst case, I’ll have the existing pads dyed parchment.
I may wait on doing anything with the console until we’re able to put the interior together in the car. Another idea I had was to use the center console as another aqua accent point and I can judge how that might look by leaving the blue console alone until that point. If it proves to be too much accent, then we can change the color to parchment. If not, we can dye it aqua.
I’m hoping to have the car ready for Carlisle 2015, but we’ll have to wait and see.
