An interesting & disturbing thing happened.
This morning, my gas pedal somehow fell off and I put it on. I had to lift the linkage up just a little bit higher then it normally goes to flip it back right side up instead of upside down.
So, thinking nothing of it, I start up the cougar to go to work to make sure it doesn’t fall off again.
When the engine warms up, the same symptoms that induced me to change to my new Edelbrock carb from the old one have returned.
I still have to investigate in daylight to make sure it’s not a coincidence and something else, but I think I either killed it or knocked it out of adjustment big time.
The link between the carb and the throttle pedal is a solid piece of what looks like 1/8th inch rebar with a series of right angle bends.
The point is that if the gas pedal is raised, the primary linkage will be rotated counter clockwise well past the normal stopping point, thus creating excessive torque on the primary shaft.
If cables attached the carb to the gas pedal shaft, there would’ve been some slack in the linkage which would protect it from damage.
With the throttle fully held down, I could have set it so it would fully open. When the throttle goes up, the carb shaft the the throttle should lift independently.
That’s not how it is. It’s one solid link. I better find out how the OEM one works. This is probably a serious mistake by whoever restored it. The thing doesn’t look stock.
Hopefully, I’ll make it home from work. It probably looks like there’s a 50-50 chance I have to get another carb. The linkage looks ok, but it probably isn’t.
Excessive torque in the wrong direction and carbs don’t play well together.
In any event, the old Holley carb has a new home to go to. The one I have now will either be fixed or stored for spare parts.
Wish me luck.
