it’s always the simple things that trip ya up. Looking for the correct adjusting nut for lock out rod for my 1970 428CJ with C-6. I have the rod 7E330-N, gotta connect to trans. lever, not sure if it is a standard adjusting nut or something with a bushing. The lever has splines inside of the hole??? Thanks guys.
It’s called a “sleeve”. You can see it in the linkage listing on WCCC.
Part # is D0OZ-7353-A. A quick search didn’t turn up any. Maybe WCCC has some good used ones. There are others out there, that are the incorrect part #. Not sure how far off they would be.
https://www.amkproducts.com/search-result/?ser=7353
