I recently installed an AOD in my 67. I have a 289 with headers and where the headers connect to my exhaust pipes it is leaning against the tranny pan and causing a leak. I am looking for any suggestions on how I can fix this. If needed I can post some pictures but it won’t be until next weekend. Thanks in advance!
The headers are long tube. No, I have not tried installing the manifolds and would prefer not to. I was told by a muffler shop that the header can be heated up and then bent a little to where it is not touching. I just wanted to see if a anyone else has experienced this problem. I am hoping to get other suggestions/opinions.
These headers fit like a glove. Clear the P/S ram without dropping it. Work with the AOD and tuck up far tighter than any header on the market. Designed by a guy that bleeds Ford blue. I have installed multiple sets of these headers and they are the best on the market and competitively priced next to other quality headers.
My Headman long tubes argued with the C6 trans over space. Before I had the exhaust made, I used a porta-power (portable hydraulic press) to gently pry the collectors away from the trans. No heat was required. Just some strategically placed blocks of wood along the subframe and being patient and taking my time was all that was needed.
