I have called a lot of shops and it seems they are not capable of anything more than toe adjustment. Since i replaced the front springs and a few suspension parts, I need that plus the camber and caster adjusted as well.
Anyone know of a shop in the metroplex that still does this?
Thanks,
mike
I went to Lake Highlands Automotive every time I needed an alignment after replacing everything. They were great and very reasonable however last time I was there was 2019.
Make sure the shop does not use the factory specs. Bring them Opentracker’s spec sheet. For radial tires you need more positive caster than with bias plys.
