Coolant is leaking from somewhere. I can’t pinpoint it. But it sprays on the passenger side fender near the solenoid. I am in the process of replacing the radiator, hoses, thermostat, and water pump. I just checked and the water pump shaft does wobble so I guess that’s what caused the wobble. I’ve heard FlowKooler is a good replacement.
Also thinking about replacing the fan clutch and fan while everything is off. May as well put on new belts too.
Is there anything else I should think of changing at this time?
If you are replacing the water pump anyway, I would not worry about the wobble now. Just make sure everything is tight when you are done and recheck for wobble then. And yes, new belts!
I was thinking about the timing chain but am worried I might screw it up. I have never done any timing before. I guess I’ll check out some videos and see if its within my wheelhouse. Did a quick search for a timing chain at West Coast Classic Cougars and one did not come up. Where do I get a replacement?
