master cylinder rebuild advice?
I’m accumulating parts to rebuild my brakes and suspension. I have discovered that my master cylinder is an original Bendix 2227161 with what appears to be an original cap. It’s in pretty rough shape but I’d like to have the original rebuilt rather than replace it with a repro. It’s a power front disc brake master.
Any recommendations for an outfit that does this?
Its going to be tough to evaluate the master cylinder until it gets disassembled if its not pitted a inexpensive brake hone can be used to renew the interior surface if pitted it will need to be sleeved Im sure WCCC could suggest a good vendor. Rebuild kits are available.
http://anghelrestorations.com/index.html
Marcus Anghel is more than capable of concours restorations of the brake master cylinder and suspension components.
After poking around a bit I found a couple places. Any opinions/experience with these two outfits?
https://www.applehydraulicsonline.com
http://therammaninc.com
Anghel Restorations seems to be the best out there but he’s probably better than I need for my driver. Maybe someday I’ll go to that level. Right now I want to use original parts when I can but I don’t have to worry about being judged in shows.
According to wccc booster video they will repair your own and get it back to you it just takes a little longer
Sorry ,master cylinder not booster .
