Well… I did It. This Cougar is mine. I found it in Austin and had it professionally inspected by a shop that specializes in classics. It spent three hours on a lift with the wheels off…literally inspecting every inch of it. The best we could tell, it’s never taken a serious hit and is rust-free. Transport dropped it off yesterday morning.
I am planning on having a local shop that specializes in Cougars do alot of the work to correct many of its “issues”. Hopefully, I’ll be able to do some of the less-complicated and non-safety-related things myself, over time. Either way, WCCC will probably run out of ink printing my shipping labels in the weeks ahead.
Anyway…I’m thinking there’s some economy and advantage to doing multiple jobs at once. What are the pros and cons of factory vs ClassicAutoAir (for reliability and comfort in the insane AZ heat)? I’d appreciate any thoughts and experiences you all may have on how to best approach this list, provided by Great Hills Automotive:
Engine
*Valve covers leaking oil
*Choke is over-aggressive
*Distributor has manifold vacuum
*Fuel system is over-complicated with a regulator and fuel filter placed resting on the intake manifold
*Engine has noise in lifter/valvetrain (possibly flat cam?)
*Exhaust headers are making contact with the clutch linkage/pitman arm
*Tailpipes need to be extended to clear body
Transmission
*Upgrade transmission to T-5 (3-speed toploader)
*Rebuild clutch linkage to correct angle of Z-Bar
*Rebuild floor pedals to safe factory spec distances
Cooling/AC
*Install air-conditioning
*Install 24” 3-core radiator with 7-blade fan and shroud
Brakes
*Upgrade brakes to 4-wheel disc
*Replace hydraulic hoses
*Repair parking brake
Suspension
*Complete suspension overhaul
*Modify stance to nose-down a bit
Steering
*Reduce steering box play
*Consider upgrading to power steering
*Replace front-end braces with single export brace
Electrical/Lighting
*Repair turn signal indicators in dash
*Replace vacuum headlight system with electrical
*Replace mechanical rear turn signals with solid-state LED
*Repair passenger side hi-beam
Interior
*Update to modern seatbelts
*Add concealed stereo system and upgrade speakers
Exterior/Body
*Reseal rear window with new gasket
*Repair small cowl leak that directs water to passenger side
*Rebuild driver-side door hinges
*Replace hood hinges
*Rebuild loose driver-side door handle
*Replace all weatherstripping
*Add passenger side mirror
Information provided by previous owner:
*3-Speed Toploader/9" Rear
*351 Cleveland: rebuilt July 19’
*Edelbrock Performer intake (original provided)
*Edelbrock AVS2 carburetor (original provided)
*Heads cleaned up
*Stainless steel valves
*Hardened one-piece pushrods
*Scorpion rockers
*Howards Rattler cam and full roller (Full Roller)
*Performance springs
*Shot -peened connecting rods
*Wesico forged pistons
*Pypes Race Pro full exhaust
*Hooker Comp headers
Thanks in advance for the help! I cant Wait to get this car fixed up and on the road!!
