No turn signal or emergency flasher, or dash indicator, when left turn lever in applied The passenger side turn signal works. The emergency flasher works, and the dash indicator on the passenger side works as well. When left turn lever is applied, I can hear the sequencer motor turning.
Where should I start?
Bump
Turn signal switch is the weak spot. Always start there
